The use of HISTORY command
All  1  2-4
11573.2 In reply to 11573.1
Hi Ray, after you create a loft through several curves the history function allows you to edit the points of the curves and the loft surface will automatically get updated with the loft recalculating. That can make it easier to control sculpted surface shaping.
That's probably the most common use for it in MOI.
I think the one in Shapr3D is a little different, I think they have the more traditional Mechanical CAD parametric feature based history where your model is made up of a feature tree with things like fillet radius values listed in the tree so you can modify those later on.
it's also very useful in the Boolean function Isect (history enabled by default)
Modify any section (or both) will modify the target form!
At any moment of the session till the target form is not modified by any other function!
Here only the circle is modified!
More elaborated! :)
EDITED: 25 Oct 2024 by PILOU
11573.4
Dear all,
Thanks so much for your help, both of you. It's very useful, I've tried it. I have done the Stylish chairs 2024 with the help of the history command which improved my work more efficiently.
@ Pilou - thank you for the youtube link because of it understand the meaning of useful command history. You can see them in the 3Dmoi Gallery.
Thank you again
Show messages: All  1  2-4
