Using Sweep on corners
All  1-2  3-8
11571.3 In reply to 11571.2
Thanks Michael. I was trying to model in real world scale, but in the end I guess it doesn't matter.
Ill check the curves for any issues and then Ill try and increase the scale.
Thank you
-B
11571.4 In reply to 11571.2
Scaling by 100% worked. Thank you Michael.
11571.5 In reply to 11571.4
Hi Billabong, also another possible technique is to do a sweep in 2 passes using 3 profile curves with the middle one slanted like this:
The pieces then will touch at their ends so they can just be joined with no extension and intersection needed.
The problem with that method is that the surface won't be an exact tube with a precise circular cross section at all points along the rail, the shape mutates a little bit as it travels along the rail and transitions from the circle profile to the slanted profile.
That's why sweep doesn't use that method currently but I would like to make it an option.
11571.6 In reply to 11571.5
Thanks Michael. What if the actual rail had more than that one corner? Say 4 different corners. Can I use 4 different profiles or is 3 the limit?
11571.7 In reply to 11571.6
Hi Billabong, there isn't any limit on the number of sweep profiles. But for this other technique you only sweep one smooth piece of the rail at a time, between 2 profiles at either end of it.
That's to avoid extensions.
11571.8 In reply to 11571.7
Understood. Thanks Michael.
Show messages: All  1-2  3-8
