Font size of Alert box
All  1-3  4-7
11565.4 In reply to 11565.3
> there is too much eye strain for numerous programs, not just MOI. So I should get a larger monitor.
Is the rest of the MOI UI ok for you by increasing Options > UI size?
I'lll see if I can adjust moi.ui.alert() to use that as well.
> The format would be... ?
Well, either HTML or PDF are good since they're cross platform.
If you call moi.filesystem.shellExecute( 'path_to_docs.htm' ); then that will display the doc file in the system's web browser or PDF viewer.
11565.5 In reply to 11565.4
Thank you Michael.
I bumped Options > UI size from 10 to 11, which is helpful.
The Alert box size does not seem to change.
11565.6 In reply to 11565.5
Hi Brian, I've got a fix for the next beta so the alert box will use the UI font size.
11565.7 In reply to 11565.6
That is great news!
Thank you Michael.
Show messages: All  1-3  4-7
