Wish list: a setting to automatically orbit (rotate view) around, say, anything hovered over
All  1  2-12
11558.2 In reply to 11558.1
Hi halmi, there are 2 different methods you can use in MOI to set the viewport rotation pivot point.
The first is the "Reset" button on the toolbar at the bottom of the active viewport:
When you click that Reset button, the view will zoom to fit the current selected object and will set the rotation pivot point to the center of the selected objects so your next viewport rotation will pivot around that object. You can push it a second time to fit to the entire model instead of just the selection, and you can right click it to do the "zoom to fit" in all 4 views (Top, Front, Right, and 3D).
The other method is the "Zoom area" button located here:
When you push that, you will pick a point which will become the rotation pivot point, and then a window for an area of interest.
Use this 2nd method if you want to pivot around some specific point on an object like the corner of a box.
> The cursor can be assigned all three coordinates to orbit as soon as it
> has something to hover over, right?
This method would result in the pivot point getting set accidentally on a frequent basis.
11558.3 In reply to 11558.1
Hi halmi, a little bit more info:
> I can't think of any modeling situation where I wouldn't want the pivot point to be consistently somewhere in the viewport.
The viewport rotation pivot point is always at the center of the 3D viewport. The eye point for the 3D view is formed starting from the pivot point.
The main things that modify it are the Reset and Zoom area viewport buttons, and panning.
When panning the pivot point shifts so that stuff like this will work:
11558.4 In reply to 11558.3
This is what's happening in an unpredictable fashion in my workspace.
When I navigate to something else, I can expect the disappearing polygon scenario half of the time.
11558.5 In reply to 11558.4
Hi halmi,
To avoid that you need to set the rotation pivot point as described above.
When you want to orbit around a particular object, select it and push the "Reset" button.
If you want to work closely on a small area of an object either select an edge or face in that area and push Reset or use the Area zoom button to snap on to a specific point.
In your video the problem is that you're not using either one of those methods.
11558.6 In reply to 11558.5
Hi halmi,
you can also set the script for quicker access to reset view:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11336.2
Mik
Why don't use the icon Rotate ?
Click edge : Reset then Icon rotate
11558.8
Thanks for the replies - I do use all the tools suggested, but I was hoping to add pivot automation to the mix. If I'm moving around a lot and working on a bunch of details, I become very aware of the extra steps. The area box is a pretty cool tool when I want to jump to a distant area and work on it, but right now I want to simply zoom seamlessly to location and just orbit at will. Using the box or reset usually throws me abruptly to a different position, where I have to make adjustments to return to where I was. And with reset, I have to make sure to deselect anything other than the intended object and select that. And after a few minor movements, I lose that pivot point and have to do it again.
Is it possible for the rotate camera command to select any hovered object as its pivot point? In any case, this is just wish list stuff. I'll try to create a video to illustrate why I would like it so much - but it's not at the top of my to-do list - continuing to design is. Thank you for your patience, Michael.
H
11558.9 In reply to 11558.8
Hi halmi,
It's difficult because MoI's view system is designed so that the 3d view is always centered on the pivot point.
If the pivot point would relocate on hover, within the current system the view would be jumping around a lot as you hovered over things.
So doing that would require some pretty substantial changes to allow the pivot point to not necessarily be on the center ray.
11558.10 In reply to 11558.9
Ah. That explains it. How about only when the command is initiated? Hovering alone wouldn't be enough. Would that limit the abrupt view shift only to the Moment of Initiation? Or...can the box or reset have the ability to simply center an object in question (selected/hovered?) without zooming in or out?
EDITED: 3 Oct 2024 by HALMI65
11558.11 In reply to 11558.10
Hi halmi,
I guess so, it sounds pretty weird though.
You can try setting this up on a keyboard shortcut, it will set the pivot point to a point you pick without doing an area window:
script: /* Set 3D view rotation pivot */ var p = moi.ui.createPointPicker(); if ( p.waitForEvent() && p.event == 'finished' ) { moi.ui.mainWindow.viewpanel.getViewport('3D').targetpt = p.pt }
11558.12 In reply to 11558.11
Thank you so much - I'll check it out, and you may be right...
...and I like it. I tap the shortcut key and click the location, There's a shift, but it's not a huge leap, and I (camera) am still pretty much where I was. I also just I took a dive back into my expired trial of Rhino to see how it was done there. They have a button called "place." Guess what it does? That's right! Except the shortcut is faster (and seems to perform more consistently) in MoI.
EDITED: 6 Oct 2024 by HALMI65
Show messages: All  1  2-12
