Moi & TopMod
 1-2  3-22  23-39
So sweet! My images ! Page bottom! So strong TopMod!
https://people.tamu.edu/~ergun/research/topology/images.html
Volume + Dome (TopMod)
Alpaca
EDITED: 26 Sep 2024 by PILOU
Moi TopMod Vizcom
Alpaca
Inside Alpaca
So Speed! Free TopMod
Alpaca
EDITED: 27 Sep 2024 by PILOU
Objects can be duplicated!
TopMod Alpaca
TopMod
Alpaca
TopMod <-- Moi3D
10 big zoom : https://imgbox.com/g/gjpdUMNfsq
Alpaca
EDITED: 29 Sep 2024 by PILOU
Modeling subdivision inside Moi ( Only SSplit & Sbridge)
At the end _SubdivBeta 9 all by Max Smirnov
Export as OBJ + Ngons
Moi3D
Alpaca
11553.13 In reply to 11553.12
Hi Pilou.
Very cool the last render!
TopMod: To have 2 objects, at first sight you have to import them together!
However, you can duplicate (easily) and move (laboriously) an object(s) already on the screen!
Join 2 identical or different facets!
Hollowing tool and customizable edges... and image or OBJ export to Vizcom!
Hollow and Wire tools A simple box and sphere, a small fillet...
A simple box and a sphere, a little fillet...
Export with Ngones mandatory since edible by TopMod!
Face selection with SHIFT pressed! Just drag the mouse over faces...TopModel is great at selection acrobatics!
The Wire tool lets you change ALL the edges at once! (There doesn't seem to be a “selective” selection for this function... To remove all the squiggles due to OBJ import, you need to delete them with the “Edge selection”, and the DEL key!
Not to be confused with the “Edge Delete” Mode function, which deletes the drawing of Edges but not the faces! (Renders Vizcom)
Free TopMod
Alpaca
In DZine
EDITED: 7 Oct 2024 by PILOU
11553.18 In reply to 11553.17
Hi Pilou!
Very cool ideas :) Props to you :)
11553.19 In reply to 11553.18
Thx....
If you use TopMod can you show the Mapping textures ?
I can't make just an image with no tiles!!!
Moi3D
Modeling with your favorite modeler...well, here it's polygonal emulated in Nurbs...but it doesn't change a thing!
(except that you get millimetric geometric precision!)
But export .OBJ from Moi before the subdive !
Then import OBJ inside TopMod for have the numerous possibilities of functions! ;)
a function for cane packaging!
In ALpaca which will disappear on October 24...chronicle of a death foretold!
11553.22 In reply to 11553.5
What renderer are you using?
>Len
Show messages:  1-2  3-22  23-39
