Moi & TopMod
 1-13  14-33  34-39
TopMod: To have 2 objects, at first sight you have to import them together!
However, you can duplicate (easily) and move (laboriously) an object(s) already on the screen!
Join 2 identical or different facets!
Hollowing tool and customizable edges... and image or OBJ export to Vizcom!
Hollow and Wire tools A simple box and sphere, a small fillet...
A simple box and a sphere, a little fillet...
Export with Ngones mandatory since edible by TopMod!
Face selection with SHIFT pressed! Just drag the mouse over faces...TopModel is great at selection acrobatics!
The Wire tool lets you change ALL the edges at once! (There doesn't seem to be a “selective” selection for this function... To remove all the squiggles due to OBJ import, you need to delete them with the “Edge selection”, and the DEL key!
Not to be confused with the “Edge Delete” Mode function, which deletes the drawing of Edges but not the faces! (Renders Vizcom)
Free TopMod
Alpaca
In DZine
EDITED: 7 Oct 2024 by PILOU
11553.18 In reply to 11553.17
Hi Pilou!
Very cool ideas :) Props to you :)
11553.19 In reply to 11553.18
Thx....
If you use TopMod can you show the Mapping textures ?
I can't make just an image with no tiles!!!
Moi3D
Modeling with your favorite modeler...well, here it's polygonal emulated in Nurbs...but it doesn't change a thing!
(except that you get millimetric geometric precision!)
But export .OBJ from Moi before the subdive !
Then import OBJ inside TopMod for have the numerous possibilities of functions! ;)
a function for cane packaging!
In ALpaca which will disappear on October 24...chronicle of a death foretold!
11553.22 In reply to 11553.5
What renderer are you using?
>Len
11553.23 In reply to 11553.22
@ Probotix
Its writed above each image! ;)
Principally free Alpaca before it's closing the 24 October 2024 ! :( :( :(
And then maybe for replace it!
The free Vizcom : an other true gem!
https://www.vizcom.ai
(Online) No limit of number image!
All is keept! (a very well managed stock).
You can make a team of 2 users (Pro infinite) working in real time on the same project! (Workbench)
You can import / export 3D models !!!
You can make 3D Model from an image...you can make animation with the layers ...an infinite screen "workbench" for any presentation!
You have 8 renders' models - A "Refine" (enhance) model -
And possibility to put an image of style desired!
Only one image by generation (pro = 4)
Quasi same hand draw rustic system than Alpaca!
The only difference is 10 seconds / generation image against 5 for Alpaca!
An very easy and simple use!
A very reactive team!
Try it! :)
Alpaca
Vizcom... as you can see maybe a little less quality in Vizcom but not so bad...
...but you can use some Refine (s) more or some other free cool enhancers like the free Krea online! https://www.krea.ai/apps/image/enhancer
Inside Krea
EDITED: 8 Oct 2024 by PILOU
Alpaca
EDITED: 9 Oct 2024 by PILOU
Topmod Alpaca
Big zoom : https://imgbox.com/g/FTE9GWcsjD
11553.26 In reply to 11553.25
Hey Pilou! This stuff is insanely cool :)
But… I gotta ask, and forgive me for doubting.
Did you create these models and renders yourself, or are they from one of those A.I. tools?
If it’s all your work, major props—you’re a seriously talented artist!
But if it’s A.I.-generated (especially the renders), well… I gotta say, that’s kinda disappointing.
11553.27 In reply to 11553.26
Of course yes the 3D model "image" is my own 3D model build with here TopMod!
After "artistic result" is the Ai result guided by any prompt from my part!
Only the result counts! Tools are just tools! :)
PS Look my signature! ;)
11553.28 In reply to 11553.27
Indeed, very cool 3d models in TopMod. My congrats :)
But...to be honest...I disagree about "Only the result counts! Tools are just tools!"
I’m really not a fan of AI-generated 3D renderings, personally. I just feel like when you go down that path, it’s not you making those renderings—it’s basically the engineers who built the software.
Nothing personal against you or anyone else, of course. No shade there.
But to me, a 3D piece created entirely by yourself, from modeling to the final render, without any AI tools, holds way more value than anything generated with AI.”
11553.29 In reply to 11553.28
Life is too short especially to the end!
No time for modelise such starships or any of these motors engine! :)
and with something like that
https://www.3daistudio.com
​ or https://www.tripo3d.ai
we can yet have some 3D models without modeling just an image is sufficient! :)
By prompt! Format GLB downloadable
From the result!
TopMod-->Alpaca
EDITED: 10 Oct 2024 by PILOU
TopMod Alpaca
Function Bridge between faces then wire
TopMod
Then Alpaca
So make any volume inside Moi ---> TopMod :)
TopMod
Alpaca
http://moiscript.weebly.com">http://moiscript.weebly.com
My Moi French Site
https://schmoll8.wixsite.com/magicavox">https://schmoll8.wixsite.com/magicavox My MagicaVoxel Gallery
11553.33 In reply to 11553.32
Really dig that 3D model you did of the snake using TopMod!
Very cool. Congrats :)
(regarding those AI-generated renderings...you already know how I feel :)
Show messages:  1-13  14-33  34-39
