Two question related to the Node Editor.
All  1-6  7-9
11541.7 In reply to 11541.1
Hi Subpa,
> Do anyone know what cause this Error and have a Solution,
> apart from copy the File to different Folder.
I think that script is using some script language functions that are only in MoI version 4 or 5, which has a newer JavaScript engine.
Probably the only other solution than moving it would be to update to MoI v4.
11541.8 In reply to 11541.7
Aah, that could be, thank you
as i dont need that Function, moving the File
will solve this
11541.9 In reply to 11541.8
Hi Subpath,
The code was changed to work with the JavaScript version the Node Editor uses. This works with both V4 and V5 beta, but not V3.
Install into this directory :
C:\Users\<username>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
Wayne
EDITED: 23 Sep 2024 by WAYNEHILL5202
Show messages: All  1-6  7-9
