Two question related to the Node Editor.
All  1-2  3-9
About icon or text button it's not so easy ;)
Better to make a short cut...
Put this in the ShortCut board
for N by example! :)
script: if ( moi.majorVersionNumber == 3 ) { moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); } else if ( moi.majorVersionNumber >= 4 ) { moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); }
Else the Delaunay node makes this... or any other thing that you want!
From this Fabulous Node Editor Elephant Library! ;) Maybe 90 % of the existing Nodes!
https://moiscript.weebly.com/biblio-elephant.html (French / English )
11541.5
thank you, Pilou
seems the delaunator.js will triangle a form/shape
i have no uses for that, so moving the file in an other folder
will not hurt
I think a Shortcut as you recommend will also be fine
so i try that
thanks a again and have a nice day
11541.6
i did not regonize that "F8" where already a Shortcut
so I just changed "F8" to "N", this shortcut is easier to reach now :)
11541.7 In reply to 11541.1
Hi Subpa,
> Do anyone know what cause this Error and have a Solution,
> apart from copy the File to different Folder.
I think that script is using some script language functions that are only in MoI version 4 or 5, which has a newer JavaScript engine.
Probably the only other solution than moving it would be to update to MoI v4.
11541.8 In reply to 11541.7
Aah, that could be, thank you
as i dont need that Function, moving the File
will solve this
11541.9 In reply to 11541.8
Hi Subpath,
The code was changed to work with the JavaScript version the Node Editor uses. This works with both V4 and V5 beta, but not V3.
Install into this directory :
C:\Users\<username>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
Wayne
EDITED: 23 Sep 2024 by WAYNEHILL5202
Show messages: All  1-2  3-9
