SavePointFile
All  1-7  8-13
11540.8 In reply to 11540.7
Hi Probotix,
Re:
> how can I find out the properties and methods of getSubObjects().items?
That's called a CurveSegment and all the methods and and properties are listed in the API:
https://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36
Re:
> Object.keys() doesnt work at the segment level.
There's a dump function in the Hints section near the top of the API to do that.
- Peer
11540.9 In reply to 11540.5
Hi probotix,
> Okay, maybe I dont understand how SavePointFile works. If I create just raw points,
> it works fine. But what I want to do is find the points of a polyline or curve and
> export those points.
Yes SavePointFile will only export point objects, not "edit points".
To export those you can convert selected curve edit points to point objects by copy/paste (ctrl+c/ctrl+v).
In v5 it's also possible to access the edit points by script, that would go like this:
var numpoints = crv.numEditPoints;
for ( var i = 0; i < numpoints; i++ )
    var pt = crv.getEditPoint( i );
    // use pt.x, pt.y, pt.z
11540.10 In reply to 11540.8
Can you be more specific about how to use the dump function?
11540.11 In reply to 11540.10
Hi probotix,
Get the file MoI_v5_API_Documentation.htm from here:
That has the code for a dump function, copy the dump function into your script and then you can call dump( obj ); which will list properties of that object.
11540.12 In reply to 11540.11
Thanks Michael!
Is there a way to launch Moi from a console and print debug info from my scripts?
11540.13 In reply to 11540.12
Hi probotix,
Sorry no there isn't a way to print debug info to a system console.
A script can show a dialog box message using moi.ui.alert( 'text' ); or it can also write to MoI's log using moi.log( 'text' ); .
You can show the log using:
moi.ui.createDialog( 'ShowLog.htm' );
Show messages: All  1-7  8-13
