SavePointFile
All  1-10  11-13
11540.11 In reply to 11540.10
Hi probotix,
> Can you be more specific about how to use the dump function?
Get the file MoI_v5_API_Documentation.htm from here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36
That has the code for a dump function, copy the dump function into your script and then you can call dump( obj ); which will list properties of that object.
11540.12 In reply to 11540.11
Thanks Michael!
Is there a way to launch Moi from a console and print debug info from my scripts?
11540.13 In reply to 11540.12
Hi probotix,
Sorry no there isn't a way to print debug info to a system console.
A script can show a dialog box message using moi.ui.alert( 'text' ); or it can also write to MoI's log using moi.log( 'text' ); .
You can show the log using:
moi.ui.createDialog( 'ShowLog.htm' );
Show messages: All  1-10  11-13
