Show dimension in standard and metric? or switch between them
All  1-3  4-7
11539.4 In reply to 11539.3
Hi Matadem,
> Thank you...what I meant is the ability to show the dimensions the measurement in mm..
> even though you are working in inch. without me editing the value.
Sorry no there isn't anything currently set up to do that without editing the value.
Here is a script you can try though, it will do the steps of editing the value for you (requires MoI v5):
script: /* Convert selected dimension to mm */ if ( moi.geometryDatabase.units != 'Inches' ) { moi.ui.alert( 'error - main units not inches' ); } else { var dims = moi.geometryDatabase.getSelectedObjects().getLinearDimensions(); for ( var i = 0; i < dims.length; ++i ) { var dim = dims.item(i); dim.text = moi.ui.formatNumber( dim.numericValue * 25.4, dim.numDecimalPlaces ) + ' mm'; } }
To use it set up a shortcut key and paste in the above. Then select a dimension and press the shortcut key.
It will convert a dim that says 1 in inches to say 25.4 mm
11539.5 In reply to 11539.3
Or try this one for displaying both inches and mm:
script: /* Convert selected dimension to mixed inches and mm */ if ( moi.geometryDatabase.units != 'Inches' ) { moi.ui.alert( 'error - main units not inches' ); } else { var dims = moi.geometryDatabase.getSelectedObjects().getLinearDimensions(); for ( var i = 0; i < dims.length; ++i ) { var dim = dims.item(i); dim.text = dim.evalText() + ' [' + moi.ui.formatNumber( dim.numericValue * 25.4, dim.numDecimalPlaces ) + ' mm]'; } }
That will set something displaying as 1" to read 1" [25.4 mm]
11539.6
That is why Moi is my main app. :D
Thank you! works awesome!!!!!!
another timesaver here.
Cool :)
Show messages: All  1-3  4-7
