Show dimension in standard and metric? or switch between them
All  1-2  3-7
11539.3
Thank you...what I meant is the ability to show the dimensions the measurement in mm...even though you are working in inch. without me editing the value.
Tried the edit it works good.
Tnx.
11539.4 In reply to 11539.3
Hi Matadem,
Sorry no there isn't anything currently set up to do that without editing the value.
Here is a script you can try though, it will do the steps of editing the value for you (requires MoI v5):
script: /* Convert selected dimension to mm */ if ( moi.geometryDatabase.units != 'Inches' ) { moi.ui.alert( 'error - main units not inches' ); } else { var dims = moi.geometryDatabase.getSelectedObjects().getLinearDimensions(); for ( var i = 0; i < dims.length; ++i ) { var dim = dims.item(i); dim.text = moi.ui.formatNumber( dim.numericValue * 25.4, dim.numDecimalPlaces ) + ' mm'; } }
To use it set up a shortcut key and paste in the above. Then select a dimension and press the shortcut key.
It will convert a dim that says 1 in inches to say 25.4 mm
11539.5 In reply to 11539.3
Or try this one for displaying both inches and mm:
script: /* Convert selected dimension to mixed inches and mm */ if ( moi.geometryDatabase.units != 'Inches' ) { moi.ui.alert( 'error - main units not inches' ); } else { var dims = moi.geometryDatabase.getSelectedObjects().getLinearDimensions(); for ( var i = 0; i < dims.length; ++i ) { var dim = dims.item(i); dim.text = dim.evalText() + ' [' + moi.ui.formatNumber( dim.numericValue * 25.4, dim.numDecimalPlaces ) + ' mm]'; } }
That will set something displaying as 1" to read 1" [25.4 mm]
11539.6
That is why Moi is my main app. :D
Thank you! works awesome!!!!!!
another timesaver here.
Cool :)
Show messages: All  1-2  3-7
