DIM TOOL(s) increase or decrease fonts
All  1-7  8-10
11538.8 In reply to 11538.5
Hi Marky,
> Is there a way to make an Arrow to be screen aligned too?
There is a setting for it which isn't exposed in the UI but can be set through a script.
If you put in this for the command part of a shortcut key it should switch the property for making the arrowhead plane rotate to face the viewer on selected dims:
script:
var objs = moi.geometryDatabase.getSelectedObjects().getAnnotations();
if ( objs.length > 0 )
objs.setProperty( 'rotateArrowheadPlaneTowardsViewer', !objs.item(0).rotateArrowheadPlaneTowardsViewer );
11538.9 In reply to 11538.8
It works great.
Thanks a million,
Marek
11538.10
Great Script,
Thank you
www.jameselliott.co.uk
Show messages: All  1-7  8-10
