DIM TOOL(s) increase or decrease fonts
All  1-5  6-10
11538.6 In reply to 11538.5
hi mk, thanks for your feedback.
it seems the font is the screen aligned function...
im using cplane a lot but dont think its what you need, best i let michael answer this!
cheers
Stefano
EDITED: 5 Jun by LIGHTWAVE
11538.7 In reply to 11538.6
was curious to see we can create "screen aligned" arrows using ANSI arrow symbols..
Here are some of the most commonly used ANSI arrow symbols along with their Alt Codes and Unicode values:
Left Arrow: ← (Alt Code: 27, Unicode: U+2190)
Right Arrow: → (Alt Code: 26, Unicode: U+2192)
Up Arrow: ↑ (Alt Code: 24, Unicode: U+2191)
Down Arrow: ↓ (Alt Code: 25, Unicode: U+2193)
Double Arrow Right: ⇒ (Unicode: U+21D2)
Double Arrow Left: ⇐ (Unicode: U+21D0)
Up Down Arrow: ↕ (Unicode: U+2195)
https://www.i2symbol.com/symbols/arrows
11538.8 In reply to 11538.5
Hi Marky,
> Is there a way to make an Arrow to be screen aligned too?
There is a setting for it which isn't exposed in the UI but can be set through a script.
If you put in this for the command part of a shortcut key it should switch the property for making the arrowhead plane rotate to face the viewer on selected dims:
script:
var objs = moi.geometryDatabase.getSelectedObjects().getAnnotations();
if ( objs.length > 0 )
objs.setProperty( 'rotateArrowheadPlaneTowardsViewer', !objs.item(0).rotateArrowheadPlaneTowardsViewer );
11538.9 In reply to 11538.8
It works great.
Thanks a million,
Marek
11538.10
Great Script,
Thank you
www.jameselliott.co.uk
Show messages: All  1-5  6-10
