Rebate Script Rabbet Fast
11537.1
Just posting a rebate script that Michael did for me a while back
It allows negative values as well. I also use it to create hollow box sections or tubes from solids
(Just set the depth longer than the solid and it basically punches through the whole shape bit like a pass through shell)
Enjoy…
https://moi3d.com/temp/steve88399/Rebate2.zip
16th May 26 just squashed image sizes, nothing new here..
EDITED: 16 May by LIGHTWAVE
Size: 123.1 KB, Downloaded: 5 times, Dimensions: 314x863px
11537.2 In reply to 11537.1
Cool! Like a sort of "Inset"... but with only one face selected!
(in Inset you can select any number of faces
Here the Rebate
With the _SubDiv_Beta9 at the end! ;)
Here Inset with 3 faces selected
EDITED: 14 Sep 2024 by PILOU
11537.3 In reply to 11537.2
Cool Pilou I thought you might turn it outside in - never thought of that !
And so ... pure rebate! :) Free Alpaca
Seems Rebate don't work directly with Subdiv_beta9!
So you must export as Format obj then Use _SubDiv_beta9 or native SubDivision !
Or better make an Negative Extrude after a SSplit! :) (so no need to export ! )
Here Multiple SSplit then Negative Extrude (careful to not make auto-intersections) then _SubDiv_beta9
EDITED: 15 Sep 2024 by PILOU
So in free Vizcom
