Hi Rik, it would probably be better to not try and bake in the rounding at the tips into the initial surface construction.
If you make sharp corners that helps improve surface quality, when curves change a lot in a small area that can tend to cause stressed surfaces with buckling.
So more like this attached version.
Then use a fillet at the end to round those edges.
