Extrusion issue
All  1-2  3-10
11535.3 In reply to 11535.2
Hi Mike
Thanks for quick response ... see attachment
Rik
11535.4 In reply to 11535.2
I dont see the construct offset in my mac version beta 5
11535.5 In reply to 11535.4
found it sorry
11535.6 In reply to 11535.3
Hi Rik, it would probably be better to not try and bake in the rounding at the tips into the initial surface construction.
If you make sharp corners that helps improve surface quality, when curves change a lot in a small area that can tend to cause stressed surfaces with buckling.
So more like this attached version.
Then use a fillet at the end to round those edges.
11535.7 In reply to 11535.6
@Michael
How do you make the first Surface ? (then Shell ? )
Sweep 2 curves
Loft 2 curves
Extrude one curve by a Path second curve
Revolve by Path
11535.8 In reply to 11535.7
I selected the curves and used Construct > Network to make the surface, and then Construct > Offset > Shell.
11535.9
thx !
11535.10 In reply to 11535.8
Cool another one for my list! :)
Show messages: All  1-2  3-10
