Onshape help
All  1-3  4-16
11534.4 In reply to 11534.1
Hi Psygorn,
> Also @Michael is it possible to have number of views exported as pdf (like selecting number
> of views for being exported as pdf) -I know it is possible to export pdf but is it possible
> to export multiple views at once?
Exporting multiple views on one page is not yet supported as a built in function but you can use the plug-in here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
That will generate a hidden line drawing with 4 views, and place the curves in the Top view and you can then export that to PDF.
11534.5 In reply to 11534.3
Hi Psygorn, here's an example generated with Make2D4Views in MoI and then exported to PDF.
11534.6 In reply to 11534.3
I upload inside Moi then export as STP
Import as multiple objects inside OnShape
and have that... top_part is the name of the entiere object!
PS
Same thing when importing as a single Object!
EDITED: 11 Sep 2024 by PILOU
Export from MOI as Sat format!
Import format Sat as "single document" inside OnShape,
No problem! No error! ;)
Import your file from Moi in 3Dm format works but have some errors!
11534.9 In reply to 11534.5
That looks promising for my needs, where can I get Make2D4Views? Is it a plugin?
-Psygorn
11534.10 In reply to 11534.7
Aha! that's what I was looking for!
-Psygorn
11534.11 In reply to 11534.9
So for your object! ;)
For the fun... with the free Alpaca :)
As no prompt so curious result of course! :)
Just an image style...
Inside the free Vizcom who has a new version !
Automatic prompt!
and different renders
11534.15
Thanks Pilou,
Thank you Michael.
-Psygorn
11534.16 In reply to 11534.15
Else... :) Maybe not so easy than inside Moi! ;)
Show messages: All  1-3  4-16
