Onshape help
All
1
2-16
Frenchy Pilou (PILOU)
11 Sep 2024 (2 of 16)
11534.2
In reply to
11534.1
Never problem with STP! :)
Maybe post your file for tests!
Or send it to Michael if you want some secrets!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Psygorn (DRILLBIT)
11 Sep 2024 (3 of 16)
11534.3
In reply to
11534.2
I can import it in Onshape, but when I want to make technical drawings I face problem!
-Psygorn
Puncher_Top_Part.stp
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
11 Sep 2024 (4 of 16)
11534.4
In reply to
11534.1
Hi Psygorn,
> Also @Michael is it possible to have number of views exported as pdf (like selecting number
> of views for being exported as pdf) -I know it is possible to export pdf but is it possible
> to export multiple views at once?
Exporting multiple views on one page is not yet supported as a built in function but you can use the plug-in here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
That will generate a hidden line drawing with 4 views, and place the curves in the Top view and you can then export that to PDF.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
11 Sep 2024 (5 of 16)
11534.5
In reply to
11534.3
Hi Psygorn, here's an example generated with Make2D4Views in MoI and then exported to PDF.
drawing.pdf
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
11 Sep 2024 (6 of 16)
11534.6
In reply to
11534.3
I upload inside Moi then export as STP
Import as multiple objects inside OnShape
and have that... top_part is the name of the entiere object!
PS
Same thing when importing as a single Object!
EDITED: 11 Sep 2024 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
11 Sep 2024 (7 of 16)
11534.7
Export from MOI as Sat format!
Import format Sat as "single document" inside OnShape,
No problem! No error! ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
11 Sep 2024 (8 of 16)
11534.8
Import your file from Moi in 3Dm format works but have some errors!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Psygorn (DRILLBIT)
11 Sep 2024 (9 of 16)
11534.9
In reply to
11534.5
That looks promising for my needs, where can I get Make2D4Views? Is it a plugin?
-Psygorn
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Psygorn (DRILLBIT)
11 Sep 2024 (10 of 16)
11534.10
In reply to
11534.7
Aha! that's what I was looking for!
-Psygorn
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
11 Sep 2024 (11 of 16)
11534.11
In reply to
11534.9
Maybe there ? ;)
Make2D4Views
https://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
11 Sep 2024 (12 of 16)
11534.12
So for your object! ;)
My Moi French Site
My MagicaVoxel Gallery
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
11 Sep 2024 (13 of 16)
11534.13
For the fun... with the free Alpaca :)
As no prompt so curious result of course! :)
Just an image style...
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
11 Sep 2024 (14 of 16)
11534.14
Inside the free Vizcom who has a new version !
Automatic prompt!
and different renders
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Psygorn (DRILLBIT)
11 Sep 2024 (15 of 16)
11534.15
Thanks Pilou,
Thank you Michael.
-Psygorn
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
11 Sep 2024 (16 of 16)
11534.16
In reply to
11534.15
Else... :) Maybe not so easy than inside Moi! ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1
2-16
