Boolean difference - one of those days!
All  1-2  3-11
11525.3 In reply to 11525.1
Hi Gunter, also Trim seems to handle this case ok so using Edit > Trim to cut the pieces up followed by Edit > Join can also be used as a workaround so you can continue with your work.
11525.4 In reply to 11525.2
Hey Michael,
Thank you! When you say rotated the circle by 90 degrees, could you explain which circle please?
I'm keen to figure out how to troubleshoot these issues on my own.. would you be able to guide me as to what I should look for specifically? I made sure, both parts were solid, not joined surfaces so I assumed any boolean operations would work.
As always, many thanks!
Gunter
11525.5 In reply to 11525.4
Hi Gunter,
This one here:
Well the weird looking result seems to be emanating from where 2 edges are crossing each other, here:
So that's the area that I would focus on.
For just getting it to work so you can move forward you can manipulate the circle used to generate the ring surface so there won't be an edge/edge crossing there.
11525.6 In reply to 11525.5
Gotcha, thank you very much Michael.
When you have a chance, I'd be interested to know what causes this issue - no rush.
Much appreciated
11525.7 In reply to 11525.2
Just to let you know that there's no issues in Moi v3
John
11525.8 In reply to 11525.7
Hey John,
Would you mind telling me how you got this to work?
Many thanks,
Gunter
11525.9 In reply to 11525.2
Thanks Michael, I did that and it worked!
Much appreciated!
Gunter
11525.10 In reply to 11525.8
HI Gunter,
As I said, I tried your file in Moi version 3 and the boolean works as expected.
I have version 3 and 4 installed on my system.
Best regards
11525.11
Hi Gunter
part of your issues are the profile you are sweeping is folding on itself in the centre at the bottom
Then when you boolean out the band it self destructs
If you change your sweep profile so does a clean sweep it will work
I have done you an alternative sweep profile to aid in setting the stone
cheers
shayne
Show messages: All  1-2  3-11
