Edge Flange Script
 1-13  14-33  34-37
11523.34 In reply to 11523.33
Hi Booleano, ok that's what is supposed to happen. So you have it installed ok.
Can you maybe describe a bit more about what problem you're having?
I thought you were having a problem with getting it set up but it sounds like you're running it ok.
11523.35 In reply to 11523.34
Hi Michael
But it only allows me 2 parameters "s" and "f"
And I want to get everything that appears in the MO example (MO_TE)
that is, the parameters of "0 1 2 3 4 5 6 7"
How is this done, I want the entire exercise
11523.36 In reply to 11523.35
Hi Booleano,
Those parameters are options you can set up in the keyboard shortcut or button that you use to launch the command.
You would use those by putting them in to the keyboard shortcut or button.
Like for a keyboard shortcut for the "Command" value instead of putting in just:
edgeFlange
you would instead put in:
edgeFlange 5 true false 4 Auto 1 false false
For a button like you have set up instead of having command="edgeFlange" you would put command="edgeFlange 5 true false 4 Auto 1 false false"
That can be helpful if you are using the command frequently with some specific values, so you can set up different shortcuts to launch it with different default values.
Edge Flange + SubDiv Beta9 by Max Smirnov
Banana
EDITED: 13 Jan by PILOU
Show messages:  1-13  14-33  34-37
