How to make frosting on a donut?
All  1-2  3-6
11522.3
I would copy your donut, cut down to where your bottom drip will be (straight line) separate the top surface and shell it to make it a solid. then cut the wiggly lines on it by creating boolen operation with a separate object.
11522.4 In reply to 11522.1
Hi Chris, it's possible to use Transform >Deform > Flow to do this but it will be a bit tricky. The donut would need to be rebuilt to be just a single surface revolved from a curve with just one segment in it and the base surface would need to be a revolved plane instead of a regular 4 corner point plane.
Instead it might be easier to create some cutting surfaces to cut the donut up and shell the remaining piece to thicken it.
11522.5 In reply to 11522.1
Something like this -
Loft a cutting surface between 2 curves for the outside:
Loft a similar cutting surface for the inside:
Use Edit > Trim to cut the donut with those lofted surfaces as the cutting objects.
That will make a result like this which you can thicken using Construct > Shell :
11522.6 In reply to 11522.5
Well that was unpleasant. Thank you everyone for your help!
Chris
Show messages: All  1-2  3-6
