Boolean Difference won't work.
All
1-2
3-4
Bob (APTIVABOY)
18 Aug 2024 (3 of 4)
11519.3
In reply to
11519.2
That wouldn't work, either. I tried solids, but no go. I was finally able to get it to work by Boolean Differencing each individual panel or surface, one after the other. Ugh... Thank you for the idea, though!
Bob
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
18 Aug 2024 (4 of 4)
11519.4
In reply to
11519.1
Hi Bob, I think the part where the booleans try to intersect the pieces is getting confused with there already being a cut through that same spot.
Instead of doing a boolean in this case you can select these faces and delete:
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-2
3-4
