MOI3D Can import and use the new rounded corner plugin for rhinoceros?
11516.1
Place the Filsrf_JoinV2.py file in the root directory of the C drive, then copy the following code to the Rhino command line and paste it, press enter
-_RunPythonScript "C:\Filsrf_JoinV2.py"
Size: 620.2 KB, Downloaded: 105 times, Dimensions: 1476x659px
11516.2 In reply to 11516.1
Hi feirui445, sorry no you can't run a Rhino plugin in MOI.
Plugins are connected to their host environment in numerous detailed ways, it's generally not possible to take a plugin developed for one program and run it directly in another.
It's kind of like asking if you can take a water pump from a truck engine and just use it in a sports car engine.
You can't because although they are similar that they both pump coolant around the shape and connections and mounting points, etc.. are very different between the 2 vehicles.
