PDF Export Scaling
All  1-4  5
11511.5 In reply to 11511.4
Hi Peer thanks for that useful information- appreciated!
I will no doubt try the bounding box ratio but for me that’s likely only valid for one off pdfs. On one of My pdf export tests I used a 0.5mm “hidden” dot above an object kind of created a boundary constraint as well; even though a bit more arbitrary.
I like to attack problems head on and that includes minimising any extra work. This workflow idea of mine is about trying to create visuals and collate potentially a lot of PDFs quickly.
I am likely to be selecting a lot of different objects or views so I feel drawing bonding boxes every time i want to control pdf output defeats the goal.
To give you some extra context-
This all started because I work in fluid ways and do a lot of screenshots from moi and/or in other programmes -BUT as it goes sometimes in moi when objects are close together or even a dimension is on a surface you get artifacts - so screenshots are out of the window sometimes. I then concluded “let’s see if we can do pdfs all the way” and look to get pdfs out of moi that can also look like the viewport.
My workflow goal is to have the highest quality “screenshots” in pdf vector format. So the end goal is this pdf export process might need to be as fast as screenshots or more flexible in rearranging them afterwards.
I’ve also emailed Michael with a few extra ideas and I think he might be making a few improvements for next beta. I sense pdf scaling might be coming very soon ;0)
Show messages: All  1-4  5
