help me
All  1-3  4-9
1151.4 In reply to 1151.3
Maybe something like this ;) (just some speedy tips so make it with more precision :) And there are always some possible methods !
Of course you can fillet the edges :)
http://www.divshare.com/download/2889362-cef
Unzip and launch in you favorite navigator the file named "ring.htm"
For the top part just make some Boolean operations
EDITED: 25 Nov 2007 by PILOU
1151.5 In reply to 1151.4
Hi billis, hi Pilou,
Very nice job on the mini tutorial Pilou! One note - it seems that your attachment above is the tutorial .zip again, not the .3dm file.
I think that the method that Pilou shows there is the easiest way for that kind of design - basically extrude one profile, and then slice away material from a second side profile.
One other option for the slicing part would be to mirror the slicer curve over to the other side, and then use those 2 slicers to cut the extrusion up into 3 pieces, that way the center part would be all one single piece instead of 2 halves joined together. Not a big deal though.
billis - you also might want to check out this other message from Jesse: http://moi3d.com/forum/index.php?webtag=MOI&msg=510.5 - this one is a different style ring than the solitaire one that is linked to in that Resources/tutorials page. This other one is in a signet type style, but it shows a different approach, one that makes a more sort of gradually curving and rounded shape.
It takes somewhat more work to set up than the "2-profiles" type method that Pilou showed, but you may be interested in the different style that results. Download Jesse's file that is attached there (MoI sweep signet_jdk.zip) and open it in MoI, and you will see the
10 different stages that Jesse used to develop the curve framework which is then swept to produce the base solid piece, and then a hole is drilled through the center part.
1151.6 In reply to 1151.5
I dug up links to several other of Jesse's jewelry-related posts and added them to that resources page.
1151.7 In reply to 1151.5
<it seems that your attachment above is the tutorial .zip again, not the .3dm file.
Ahhhhh damned! :)
So here a little more quicky and this time with an half circle for have a continuous form on the bottom part :)
And now with the 3dm :)
EDITED: 26 Nov 2007 by PILOU
1151.8 In reply to 1151.7
pilou my friend thank u so much.ur tutorial is so good.thank u so much again
i fixed in few minutes with ur tutorial.(so simple that make me ungry with myself,but i am bigener)
thanks again
basilhs
1151.9 In reply to 1151.8
@billis
Have fun with Moi, one of the more easy exciting prog at this date :)
Show messages: All  1-3  4-9
