V5 Notes Feature - two scripts and 1st Step to Automation?
All  1-8  9-11
11509.9 In reply to 11509.8
Hi Michael the code looks very compact / efficient
So I think when you say
moi.vectorMath.createTopFrame() );
That means xyz = 0 and that expression = default position.
But if I wanted it to be less efficient with the code or longhand and see where to change xyz the values by code, I guess it is:
var frame = moi.vectorMath.createTopFrame();
frame.origin.x = 0;
frame.origin.y = 0;
factory.setInput( 0, frame );.
[where’s the z though ? is it in the empty () after Top Frame or is it in the set input ( 0, frame );
or can we have -
frame.origin.x = 0;
frame.origin.y = 0;
frame.origin.z = 0;
11509.10 In reply to 11509.9
Hi stefano, yes that last one should work:
frame.origin.x = 0;
frame.origin.y = 0;
frame.origin.z = 0;
11509.11 In reply to 11509.10
Thanks again Michael. I’ve just moved my level of coding upwards from zx81, y0; Moi.factory.setitlikeapun);
Show messages: All  1-8  9-11
