Tanget Edges - Chain Select
 1-5  6-25  26-31
11506.26 In reply to 11506.19
Hi MO,
It works now! I changed the name to "ExtendEdgeSelection"
By the way I did not run the script by typing in the input field nor a short key! I simply choose it from scripts menu and it didn't work!
but now it works! after applying your simple remedy. :-)
-Psygorn
11506.27 In reply to 11506.26
Have you an image of your scripts menu ?
11506.28 In reply to 11506.27
Yes Pilou,
Here:
11506.29 In reply to 11506.28
Must be a specific UI different than Custom UI
In any case that take the original names files existing! )
11506.30 In reply to 11506.28
I see you don't have the same name as your file: ExtendEdgeSelection.js, on the drop-down menu I read: Extend Edge Selection!??
EDITED: 14 Aug 2024 by ZOOEN
11506.31 In reply to 11506.30
Hi Zooen,
The screenshot is taken when I had problem running the script. After MO's suggestion on changing the .js file's name; things started to work as they supposed to.
It means if I send u a new screenshot there u will see "ExtendEdgeSelection" instead of "Extend Edge Selection"
And I congratulate you; it seems you have keen eyes! ;-)
- Psygorn
Show messages:  1-5  6-25  26-31
