Another filleting issue
All  1-2  3-9
11505.3 In reply to 11505.1
Hi Gunter, so the other thing is the fillet will get extended because a spot like this is not a place where a fillet can end:
The fillet wants to intersect with a kind of "capping face" and there is not any such face at that spot.
So instead of opening up a hole in the object there, it will continue on until it finds a suitable face for the fillet to be intersected with like this one shown in yellow here:
11505.4 In reply to 11505.3
Hey Michael, thank you for the detailed explanation.
In my file I actually booleaned the 2 parts so they are one but if I'd like to fillet the part to the end of the yellow line, what would you suggest I do?
11505.5 In reply to 11505.4
Hi Gunter, it kind of looks like there is a little shelf-like structure in this area here:
I'll see if I can clear that out for you to give fillets a better chance.
11505.6 In reply to 11505.4
Hi Gunter, please try with this attached version:
11505.7
Hey Michael, you're right, I deleted that rectangle and it worked!
Thank you so much!
Gunter
11505.8
Hello,
Booleans can be a good option in this case.
1. Draw solid > Box
2. Draw curve > Circles aligned to Box
3. Select circles, Construct > Boolean > Isect
4. Select box, Construct > Boolean > Diff, select isect solid
5. Draw curve > Circles, align, select circle, Construct > Extrude
6. Select hollowed box solid, Construct > Boolean > Diff, select cylinder
7. Fillet box / cylinder edges
8. Fillet inside box edges
Boolean Box
EDITED: 2 Feb 2025 by OSTEXO
11505.9 In reply to 11505.8
Hey OSTexo,
This is very helpful, thank you!
Show messages: All  1-2  3-9
