Boolean
All  1  2
11502.2 In reply to 11502.1
Hi Booleano, if you're trying to cut the ellipsoid into 2 pieces, start by selecting the ellipsoid solid only. Then run Construct > Boolean > Difference and then when MoI says "Select objects to subtract" select the cutting curve and push "Done".
That will cut the ellipsoid into 2 separate solid pieces.
Show messages: All  1  2
