Flipped normals on export on a solid
All  1-5  6-11
11500.6 In reply to 11500.1
It appears to be these 2 faces here, if these are removed the orientation is ok:
11500.7 In reply to 11500.6
There's an edge in there that's squashed down to to a point.
11500.8 In reply to 11500.1
Hi Billabong, please try with this attached version. I removed the squashed edges (using untrim) that were on those 2 faces.
11500.9 In reply to 11500.5
Hey Michael,
Sorry for the late reply. Thank you so much for fixing this. If you have a min. can you explain in some more detail on how you found the error? Did you just export out sections and bring that into 3D package to see if the problem?
@ PaQ,
Thank you for trying as well. It so much appreciated.
-B
11500.10 In reply to 11500.9
Hi Billabong,
Yes I broke it up into chunks and noticed that some pieces were exporting unified normals ok. So I took those pieces and gradually made them larger.
11500.11 In reply to 11500.10
Understood. Thank you again
Show messages: All  1-5  6-11
