Flipped normals on export on a solid
All  1-3  4-11
11500.4 In reply to 11500.3
Hi Michael, how do you manage to isolate the problematic area ? was it just a guess ?
11500.5 In reply to 11500.4
Hi PaQ, I tried testing some isolated chunks of the model and saw that they were making consistent normals ok and with repeated testing narrowed it down to that area.
Now I'll see if I can narrow it down further yet, there is probably a damaged trim boundary in there somewhere.
11500.6 In reply to 11500.1
It appears to be these 2 faces here, if these are removed the orientation is ok:
11500.7 In reply to 11500.6
There's an edge in there that's squashed down to to a point.
11500.8 In reply to 11500.1
Hi Billabong, please try with this attached version. I removed the squashed edges (using untrim) that were on those 2 faces.
11500.9 In reply to 11500.5
Hey Michael,
Sorry for the late reply. Thank you so much for fixing this. If you have a min. can you explain in some more detail on how you found the error? Did you just export out sections and bring that into 3D package to see if the problem?
@ PaQ,
Thank you for trying as well. It so much appreciated.
-B
11500.10 In reply to 11500.9
Hi Billabong,
Yes I broke it up into chunks and noticed that some pieces were exporting unified normals ok. So I took those pieces and gradually made them larger.
11500.11 In reply to 11500.10
Understood. Thank you again
Show messages: All  1-3  4-11
