Grid showing with snap shot
All  1-4  5-12
11498.5 In reply to 11498.3
Hi Tim, yes so that is some customized UI.
I think the script for it is probably located in this folder:
~/Library/Application Support/Moi/startup/
And probably called something like "84 Snapshot.js", do you see it there? If it's an older version it might be in a different spot though.
What happens if you right click on the button instead of left click? I think that particular script may have been set up to show grid on left click and hide it on right click.
Also if you hold down Ctrl and/or shift when you click it will also do a slightly different size or color variation.
11498.6 In reply to 11498.5
Double click has got rid of the grid, many thanks.
Screen shot prints onto a grey background and I would prefer a white background for printout. The "hold down Ctrl and/or shift" did nothing thjat I could tell, still grey background.
I could not find the Moi sub folder in the Applications support folder.
Tim
11498.7 In reply to 11498.6
Hi Tim, the "Library" folder is hidden by default so it can be a bit tricky.
From the Mac finder try going to the "Go" menu on the top menu bar and pick the "Go to folder" menu item then put in ~/Library/Application Support/Moi
Is there a "startup" folder inside there and a file named "snapshot" in it?
11498.8 In reply to 11498.4
Hi Mip
Thanks for the script...not too familiar with script usage, so will have to work out how to insert.
Many thanks for reply anyhows
Tim
11498.9 In reply to 11498.8
Hi Tim, for using the script in Mip's message above, go to Options > Shortcut keys and push the "Add" button and then press what key combination you want to trigger it. Then paste in the script code for the "Command" value of the shortcut key.
11498.10 In reply to 11498.4
Hi Mip
Thanks for this, worked a treat.
T
11498.11 In reply to 11498.9
Thanks for this, managed to paste in script and use OK. One thing though, my screen put the grid on after using the script, had to go into Options to remove the grid. I was using short cut key as Mip had used Ctrl, Alt, S. Any idea why grid appeared back on screen?
thanks
Tim
11498.12 In reply to 11498.11
Hi Tim,
It's just what the script does - it turns off the grid, takes the snapshot, then turns on the grid.
Try this variation which will save the current grid display state and restore it instead of just turning it off and on:
script: /* Generate viewport image white background 4000, 2500 linewidth : 4 */ var prev_background = moi.view.viewportBackgroundColor; moi.view.viewportBackgroundColor = 0xFFFFFF; var prev_linewidth = moi.view.lineWidth; moi.view.lineWidth = 4; var prev_griddisplay = moi.grid.display; moi.grid.display = false; var prev_showxyaxes = moi.grid.showXYAxes; moi.grid.showXYAxes = false; var prev_showaxisicon = moi.view.showAxisIcon; moi.view.showAxisIcon = false; var prev_showviewtitles = moi.view.showViewTitles; moi.view.showViewTitles = false; var img = null; try { img = moi.ui.getActiveViewport().render( 4000, 2500 ); } catch(e){} moi.view.lineWidth = prev_linewidth; moi.grid.display = prev_griddisplay; moi.grid.showXYAxes = prev_showxyaxes; moi.view.showAxisIcon = prev_showaxisicon; moi.view.showViewTitles = prev_showviewtitles; moi.view.viewportBackgroundColor = prev_background; var name = img.getSaveFileName(); if ( name != '' ) img.save( name );
Show messages: All  1-4  5-12
