View face
All  1  2-4
11495.2 In reply to 11495.1
HI gunter
Perhaps using CPlane...
https://moi3d.com/4.0/docs/moi_command_reference5.htm#cplane
you can also re-orient your part
chri
EDITED: 1 Aug 2024 by CHRI
Size: 49.6 KB, Downloaded: 42 times, Dimensions: 430x467px
Size: 9.2 KB, Downloaded: 29 times, Dimensions: 412x234px
11495.3 In reply to 11495.1
Hi gunter, yes like chri writes above you can use View > CPlane to set the construction plane to align with the face.
When you do that the Top/Front/Right views will be oriented around that plane (unless you uncheck "Orient ortho views").
When you want to reset back to the default world top/front/right views you can right click on View > CPlane.
11495.4
Thank you both, that worked! :)
Gunter
Show messages: All  1  2-4
