V5 beta Jul-30-2024 available now
 1-17  18-37  38-57  58-70
11493.18 In reply to 11493.17
Hi Isleofgough,
> Unfortunately, this beta version will not open in OSX 15
There is a file "Install instructions readme.txt" file included in the .zip file, did you do the steps in it?
11493.19 In reply to 11493.17
Hi Isleofgough,
I set up macOS 15/"Sequoia" over here and the v5 beta is working fine for me after following the install readme instructions.
For MoI v4, it used to be enough to right click on the app and choose "Open" on the pop up menu for the first time running it. But with Sequoia that won't work anymore. You instead need to go to System Settings > Privacy & Security and there will be an option there where you can allow it to run.
Some more info on this here:
https://www.idownloadblog.com/2024/08/07/apple-macos-sequoia-gatekeeper-change-install-unsigned-apps-mac/
11493.20
Hi Michael et al,
MoI V5 beta includes a function to copy SVG curves to the copy buffer. Does anyone happen to know if it's possible to paste that buffer into Blender? Blender natively supports SVG, but after copying a curve to the SVG buffer using script: moi.geometryDatabase.copyToClipboardSVG(); and pressing Control + V in Blender, nothing happens.
Thanks!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
11493.21 In reply to 11493.20
Hi Metin, I tested with Ctrl+C copy from Inkscape as well with the same non result trying to paste into Blender.
So it looks like Blender does not currently support pasting in SVG format ("image/svg+xml") from the clipboard.
That's a feature request to make for Blender.
11493.22 In reply to 11493.21
Thanks for checking, appreciated. You're right, this should be a Blender feature.
Cheers,
─ Metin
11493.23
OK, submitted the feature request. Anyone who would welcome pasting of MoI's SVG copy buffer into Blender, please upvote the request, thanks!
https://blender.community/c/rightclickselect/7nQG/
─ Metin
11493.24 In reply to 11493.23
The perspective switching is ineffective in version V5. Can it be repaired?
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) { viewport.viewPanel.mode = viewport.name } }
11493.25 In reply to 11493.24
Hi feirui445,
It's working fine for me in v5. What problem are you having?
- Peer
11493.26 In reply to 11493.24
Hi feirui445, yes that's working ok for me too. If you're in "split" mode when you trigger it, is your mouse pointer over the view you want to switch to?
If your mouse pointer is not over the viewport then it won't do anything.
11493.27 In reply to 11493.20
Hello,
How can I get objects from one layer to another layer?
In my file there are 2 layers K2-Balkon.
I would like to merge these two layers into the layer that is in the K2 group.
Hier die MOI-Datei:
www.cad-exact.de/moi_v5/Kreisgebaeude-04.zip
Bye
Andreas
11493.28 In reply to 11493.27
it's that you want ?
Just select something
go to the Groups wanted
Click on it "Assign Selection here" = Selection go to this Group!
PS Rename as you want if necessary because Group01, Group02 are not very descriptive! :)
If you want only one group from the previous...so like a "merge"...
Ungroup the Group02 selected
as it's yet selected...Goto Group01
All is inside one group...
Like this you can make some complex arborescences without big headaches! :)
EDITED: 31 Oct 2024 by PILOU
11493.29 In reply to 11493.27
Hi Andreas,
So like Pilou mentions above, the main way is to select it (click on selection dot) and then click on the name label where you want it to go and choose "Assign selection here".
There are some complicating factors for your case here though.
One thing is that those objects are hidden, and you can't select objects that are hidden.
So those need to be shown before clicking on their selection dot, or there is a shortcut if you hold down shift while clicking the selection dot that will show it and select it.
Also another shortcut is that you can right click on a name label to do "Assign selection here" without showing the regular menu.
But there's another complicating factor which is that some of these names are assigned to edges and edges will not want to be shown if their owning surface or solid is itself hidden.
It may be a good idea to purge the names off of edges.
You can do that by showing everything ( "Hide" button on Edit palette on side pane), clear selection, go to Types > Edges and click selection dot, then click on name field in properties panel showing "(varies)" and assign a blank name.
That will get rid of some of the misbehaving names in the browser.
Let me know if you need more details.
11493.30 In reply to 11493.27
Hi Andreas, also another way to remove names from edges is to set up this on a shortcut key:
script: /* Remove names from edge sub-objects */ var breps = moi.geometryDatabase.getObjects().getBReps(); for ( var i = 0; i < breps.length; ++i ) { breps.item(i).getEdges().setProperty( 'name', '' ); }
That will get rid of the "K2-Balkon-2" that's at the top which is set on an edge sub object.
11493.31 In reply to 11493.30
Hi Frenchy, Hi Michael,
Your tips were very helpful.
Many thanks for that.
I immediately put the script on F2, it works perfectly.
Can moving be made easier?
For example, simply change the assignments in the object list using drag and drop?
It would be helpful if in this list:
the existing layers could be selected from the object list.
Bye
Andreas
11493.32 In reply to 11493.31
Hi Andreas, drag and drop can get very awkward when lists get longer and you need to try and control scrolling within the drag/drop as well.
I've been trying to avoid using it.
Maybe I can add a "Move" item to the pop up menu that currently has "Assign selection here" and "Rename" on it. The "Rename" there allows you to rename an item without having to make it selected first. A "Move" item there could be similar, it could wait for you to click on another item in the list and assign it there without needing to set selection.
You're getting to that by clicking the name line in the properties panel here, is that correct?
If you want to set it to an existing name, don't use that method - instead click on the name in the Scene browser and choose "Assign selection here", or you can also right click on it which will assign it without having the menu pop up.
11493.33 In reply to 11493.32
Yes.
<If you want to set it to an existing name, don't use that method - instead click on the name in the Scene browser and choose "Assign selection here", or you can also right click on it which will assign it without having the menu pop up.
Works perfectly :-)
Bye
Andreas
11493.34 In reply to 11493.33
Hello Michael,
If objects with the same name are in a group, I can only access individual areas etc. by double-clicking.
If I dissolve the groups, the individual objects can be reached with a single mouse click,
which I find better!
Is this behaviour desired for grouping?
If so, why?
Bye
Andreas
11493.35 In reply to 11493.34
maybe you can use this for rename all objects of a selection so no double name! :)
> Is there any possibility to create a script that will number objects depending on the sequence of clicking on them?
Try this:
script: /* Set name by selection order */ var objs = moi.geometryDatabase.getSelectedObjects(); objs.sortBySelectionOrder(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.name = i+1; }
http://moiscript.weebly.com
My Moi French Site
https://schmoll8.wixsite.com/magicavox
My MagicaVoxel Gallery
11493.36 In reply to 11493.34
Hi Andreas,
Yes, that's correct. The click selection behavior is the same whether you have objects with the same name or with different names.
I've attached an example file here, the group on the left contains objects with the same name, the group on the right contains objects with all different names.
You should see the same viewport click selection behavior on both.
If you are seeing a difference in behavior with same name vs different names, can you please post an example file?
Also, if you hold down the Ctrl key when you click, it will drill down to immediately select that individual object inside the group instead of going in steps like plain left click does.
Yes, this is the intended behavior.
> If so, why?
Because that's the behavior of the vast majority of software that has a function called "groups".
For example Affinity Designer, Adobe Illustrator, Inkscape, Rhino, MS Word.
It's an organization method that helps to make a number of objects stay together and behave as one unit.
In the future I want to add some other types of organizing (called "folders", probably) that will behave differently. But grouping was frequently requested so it has been the priority for hierarchical organizing tools.
11493.37 In reply to 11493.36
thank you for the detailed explanations.
I think it would be helpful to be able to sort the stiles alphabetically, in ascending or descending order.
Bye
Andreas
Show messages:  1-17  18-37  38-57  58-70
