Troubles with solids
All  1-6  7-9
11491.7 In reply to 11491.5
Hi jki,
> In one step, adding a detail the solid is "broken" to a joined surface... despite the operation does NOT
> affect the areas which are now marked as naked edges.
Non-manifold or self intersecting geometry can affect operations on other areas of the model too. Particularly mechanisms that involve traversing connected faces.
> So it means there is something wrong with faces... Is there a way how to identify it and prevent such situation?
Is this on the same model that you posted above? Because like I wrote above, the thing that is wrong there is having places where 4 surfaces are touching at a single edge making a non-manifold structure.
> Is there an the explanation why in some cases the "boolean Union" end up as Boolean Difference?
One of the things that non-manifold/self-intersections can mess up is the algorithm that identifies which side of a closed skin is the outside.
If it ends up classifying the wrong side as the outside it can invert which pieces are kept and discarded in booleans.
11491.8 In reply to 11491.6
Hi Larry,
> If so, would it be reasonable (possible) for MOI to warn when an operation produces object(s) whose
> "type" is lower in the hierarchy than they were when the operation commenced?
It would be hard to do this for everything because there are some functions (Edit > Separate, Trim) where their job is specifically to produce a "lower" result.
It could be good for booleans though.
The complication is that there is not an established UI mechanism for reporting a command specific error.
I have some ideas on making a command "epilogue" dialog that could work for that, I hope to be able to experiment with it in v6.
11491.9 In reply to 11491.8
Thanks Michael,
Sounds like this would make a good wish-list item combined with your command "epilogue" dialog to check for degraded object types from certain ops like the booleans.
--Larry
Show messages: All  1-6  7-9
