Boolean
 1-3  4-22
Message 11487.4 deleted 21 Sep 2024 by BOOLEANO
Message 11487.5 deleted 21 Sep 2024 by BOOLEANO
11487.6 In reply to 11487.4
Seems you have not the good start plane surface!
you must have 2 sorts of geometric figures!
12 pentagons & 20 hexagons
So maybe for the flow take only the 12 pentagons! ;)
You will obtain directly the missing hexagons! ;)
EDITED: 27 Jul 2024 by PILOU
11487.7 In reply to 11487.4
Hi Booleano
> This example is not mine, but I think it was done with the Flow function, but how?
The completed soccer ball here was not done with Flow, because doing Flow from a plane onto a sphere will have compression in the deformed objects at the "pole" areas of the sphere.
But you can construct a polyhedron from a flat pattern by using Transform > Rotate > "Rotate axis" along with some construction circles to snap onto.
The technique is shown in these previous discussion threads:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2140.46
http://moi3d.com/forum/index.php?webtag=MOI&msg=911.11
Message 11487.8 deleted 21 Sep 2024 by BOOLEANO
Message 11487.9 deleted 21 Sep 2024 by BOOLEANO
Message 11487.10 deleted 21 Sep 2024 by BOOLEANO
11487.11 In reply to 11487.10
I don't tried it... i will see that!
Another thing: ask Show Points for see the radial "top poles"
Maybe you can trim them and remplace them by another same size meridian poles ! ;)
So maybe more suitable for the Flow! ;)
Rotate the seam
Draw a square for trim the Poles N S
Boolean Merge or Trim for have 4 poles + middle surface
Kill North - South Poles
Copy rotate Left Right Poles
Join all = a solid sphere!
You must have a sphere with North South poles for use the Flow with more facility! ;)
EDITED: 29 Jul 2024 by PILOU
Not yet perfect but....
PS Another idea..
if resulting forms are deformed just draw the start forms with the "opposite" forms! ;)
Message 11487.14 deleted 21 Sep 2024 by BOOLEANO
My 2 cents.
MoI is not the easiest way to create this volume from scratch.
I think the easiest way is to use a software with a constraint resolver.
MoI don't have such feature.
You create pentagons and hexagons using same edge length.
Next, you add constraints to force your edges (or points) to be joined.
11487.16 In reply to 11487.13
Hi Pilou & Booleano - it isn't possible to apply a flat 2D plane onto a sphere without stretching or compression.
It's just a fundamental fact of geometry.
That's why Flow is not going to be the right tool for doing that.
Again, the technique that can be used for modeling a polyhedral shape is to draw polygons that have shared edges and then use Transform > Rotate > "Rotate axis" to pivot the polygons upward around the shared edge.
This is described and demonstrated in these previous posts:
11487.17 In reply to 11487.15
Hi Phiro,
A constraint solver isn't needed - you can just draw 2 vertically oriented circles that then intersect at the needed point for rotate axis to snap on to.
More details here:
11487.18 In reply to 11487.16
Yep but as adventure game that is perfect from time to time! :)
I don't desesperate to find a solution! :)
Another strategy...
Make a sphere from Subdivision! :)
It's winning for Flow if exists a geometric division by 6 surfaces of the soccer ball!
PS Trivial question...
Why the subdivision surface still stay in 6 separate faces and not redone a normal sphere when join or union?
11487.20 In reply to 11487.19
The subdivision surface sphere is not quite exactly spherical.
Since it is not an exact match for a sphere there isn't any mechanism to try and convert it into an exact sphere.
If you want an exact sphere, you can make one with the Draw solid > Sphere command, instead of using SubD conversion.
11487.21 In reply to 11487.1
Hi Booleano,
Could you tell what u want to do? What do u mean by "resolve this file" ?
- Psygorn
11487.22 In reply to 11487.15
Hi Phiro,
but I think MOI is the easiest way to create this volume! :-)
-Psygorn
Show messages:  1-3  4-22
