Boolean
 1-16  17-22
11487.17 In reply to 11487.15
Hi Phiro,
> I think the easiest way is to use a software with a constraint resolver.
A constraint solver isn't needed - you can just draw 2 vertically oriented circles that then intersect at the needed point for rotate axis to snap on to.
More details here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2140.46
http://moi3d.com/forum/index.php?webtag=MOI&msg=911.11
11487.18 In reply to 11487.16
Yep but as adventure game that is perfect from time to time! :)
I don't desesperate to find a solution! :)
Another strategy...
Make a sphere from Subdivision! :)
It's winning for Flow if exists a geometric division by 6 surfaces of the soccer ball!
PS Trivial question...
Why the subdivision surface still stay in 6 separate faces and not redone a normal sphere when join or union?
11487.20 In reply to 11487.19
The subdivision surface sphere is not quite exactly spherical.
Since it is not an exact match for a sphere there isn't any mechanism to try and convert it into an exact sphere.
If you want an exact sphere, you can make one with the Draw solid > Sphere command, instead of using SubD conversion.
11487.21 In reply to 11487.1
Hi Booleano,
Could you tell what u want to do? What do u mean by "resolve this file" ?
- Psygorn
11487.22 In reply to 11487.15
Hi Phiro,
but I think MOI is the easiest way to create this volume! :-)
-Psygorn
Show messages:  1-16  17-22
