Odd issue with circular array and boolean
All  1  2-8
11474.2 In reply to 11474.1
Hi Gunter,
The problem is caused by the ovals having an edge that is very close to being coincident with the surface of the ring:
I moved one of the ovals that wasn't working away from the ring slightly:
and boolean diff worked fine then.
I don't get the deformed oval like you show. For whatever reason, that one actually worked ok for me. But, it's generally a bad idea to have surfaces or edges just grazing one another for booleans. Just like a surface has edges, some curves have points where they are joined and those points can also cause problems if they are very close to lining up with an edge or a point on the other object in the boolean.
- Peer
You must redraw all! ;)
Your ring or gem sections and volumes are a mess of Control Points!
Rebuild fonction is your friend! But better to redraw directly!
Name your objects for a more practical selection!
Try to put the "generative curve" out of the volumes!
That avoid problem!
EDITED: 17 Jul 2024 by PILOU
11474.4 In reply to 11474.3
I just drew the ovals with one curve and then revolved. Do all these points come because of the flow?
And how do I reduce the number of points without having to click on each one?
Sorry for all the questions, I'm trying to understand how best to create these objects.
Many thanks!
11474.5 In reply to 11474.2
Hi Peer,
Great thank you, I'm going to try that right now!
Many thanks!
Gunter
11474.6 In reply to 11474.4
As i said you have 2 possibilities: select a curve section
press Tab and write Rebuild (hidden function)
Take a number of Points wished...Enter
but you have better way to redraw the section with few Control points
As you see my ellipsoïd volume has very few control points
When I said generative curve out any volume that is this!
if you can of course !
11474.8 In reply to 11474.6
Thank you so much Pilou!
Gunter
Show messages: All  1  2-8
