Installing Custom UI
All  1-2  3-6
11472.3 In reply to 11472.2
Michael, as always thank you, it works great now.
11472.4 In reply to 11472.2
Michael,
There are some buttons in the Custom UI that display menus,
Is there a way to display these menus using shortcut keys rather than the Custom UI buttons?
11472.5 In reply to 11472.4
Hi Mindset,
Try setting this up for the "Command" part of the shortcut key:
script: moi.ui.showMenu( 'moi://appdata/customui/Scripts.menu.htm', moi.ui.commandBar.CommandBarCustomUI, 0, 0 );
script: moi.ui.showMenu( 'moi://appdata/customui/ScriptsFull.menu.htm', moi.ui.commandBar.CommandBarCustomUI, 0, 0 );
I don't seem to have a Shortcuts button over here, if you can find the .js file for it in your startup folder, look for a line like this that will contain the URL to use for the first parameter to moi.ui.showMenu():
var menu = "moi://appdata/customui/ScriptsFull.menu.htm";
11472.6 In reply to 11472.5
This works great!
Bravissimo
Show messages: All  1-2  3-6
