Flow Target surface issue
 1-16  17-36  37-42
11471.37 In reply to 11471.34
Hi Gunter,
you do not need to select all your objects only one (the red one) as shown the in my illustration.
I have attached my drawing to help.
I have shown the centres as circles just for reference.
1) run ArrayGem
2) select in browser Gem and in ArrayGem done.
3) select in browser Points then Ring and in ArrayGem done.
This will place the gems on the points orientated to the ring surface.
You can adjust the depth by moving the circle position.
Hope this helps
Barry
If you use Vclone you can have different sizes in the same time! ;)
11471.39 In reply to 11471.37
That's brilliant Barry, thank you very much!
Gunter
11471.40 In reply to 11471.38
Thank you Pilou, very helpful as always!
Gunter
Michael has repaired the _VSeed shown above!
http://moi3d.com/forum/index.php?webtag=MOI&msg=11471.23
https://moi3d.com/download/scripts/max/vSeed.v.1.3.2024.07.16.zip
Put the 2 files unzipped on the Moi commands folder
No more error message!
11471.42 In reply to 11471.41
Brilliant, thank you so much Pilou!
Gunter
Show messages:  1-16  17-36  37-42
