Import 3dm Rhino file for Blender
All  1-2  3-5
11463.3 In reply to 11463.2
“””””” I did some tests but the 3dm files saved with Moi3D surfaces are not imported while those saved with RhinoV5 are imported correctly,and wonder why?”””””
Rhino uses a concept of saving the “display render mesh”
They arent using NURBS. It is basically a polygon model
MoI does not save this mesh data in a 3dm.
You should be able to get the same results if you do a “save small” in rhino. This drops out the render mesh to save on file sizes.
11463.4 In reply to 11463.3
I thought and assumed that the add-on also makes on fly the tessellation.
11463.5 In reply to 11463.2
Some more details on what Burr mentions here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5875.3
Often times 3DM import plugins like this kind of take a shortcut and don't do any tessellation of their own. Instead they rely on a cached tessellation being present in the file. MoI doesn't write that because it significantly bloats up file size.
EDITED: 6 Jul 2024 by MICHAEL GIBSON
Show messages: All  1-2  3-5
