Orient - I think?
All  1-2  3-5
Another way is to use flow again...
But this use has to be using rigid option of FLOW
You place your stones in your original grid and use the same source and target surfaces (but with rigid option)
11462.4 In reply to 11462.3
Thank you Pilou! Of course I can, duh - sometimes the old brain just doesn't put 2 and 2 together!
11462.5 In reply to 11462.1
唯一的建议是将戒指圈的需要配对目标曲面,在原位复制一份(Selected edit→copy→paste)将戒指圈隐藏起来,再进行定位之类的操作,这可以有效避免捕捉不准确带来的问题。
(The only suggestion is to match the target surface of the ring ring ring, make a copy in situ (Selected edit → copy → paste), then hide the ring ring, and perform positioning and other operations, which can effectively avoid problems caused by inaccurate capture.)
Show messages: All  1-2  3-5
