Meshing Options Quads & Triangles
All  1  2-13
11459.2 In reply to 11459.1
Hi Nick,
> In the 'Quads & Triangles' mode i noticed that the quad mesh is forced onto
> the connecting edge. Is it possible to avoid that?
Probably not, because it's likely that those vertices that you indicate are added in to the edge tessellation so that it meets the angle value.
But it's hard to give feedback on what's going on just by looking at a screenshot. Can you please post the .3dm model file for the object you are meshing so I can look at the actual geometry?
Thanks, - Michael
11459.3 In reply to 11459.2
It's kinda hard to articulate sorry.
it would be great i the last lines of the quad surface tesselation/subdivision that create the connecting vertex points could be removed.
it's nothing related to a project, i'm just testing. i uploaded a simple test scene.
Nick
11459.4 In reply to 11459.3
Hi Nick, so you mean that you want the polygon edges between those red dots to not be there so those would be quads instead of triangles?
Currently it only tries to make quads for polygons that are grid aligned to the UV space.
If it tried to make quads in the spots you indicate, that would probably have somewhat odd shaping in other spots as well like here:
There would probably be other cases where quads like that would be non convex as well.
Note that for your example here if you set "Divide larger than" to only apply to curved surfaces and not planes you can get a result like this:
11459.5 In reply to 11459.4
Thank for the detailed reply.
Yes, because it is the top surface (in this case) that adds additional vertex points to the evenly spaced curved surface.
(I don't know how this can be evaluated with math.)
The curved surface marked bellow would have to be prioritized since it defines the evenly spaced curve points.
This screenshot also shows the expected result for the mentioned area.
The 'Curved' option unfortunately looses the top quad tesselation.
This side points must have already some kind of threshold to not add a new point since it be too close to an existing one or match the coordinates exactly.
Nick
11459.6 In reply to 11459.5
Hi Nick,
Unfortunately the mesher does not currently work in an order dependent way like this with some faces having priority over others.
If you change it to Output: N-gons, you can see that the vertices you don't like are getting added because of the top plane being divided (because Divide larger than "All" is set).
If you want to get all quads on the top face the best way is to use a retopology process in a polygon mesh modeling app.
11459.7 In reply to 11459.6
I believe using vanilla Blender I may have resolved your issue.
I downloaded your 3dm model and imported into Moi3D 4.0
And exported to an OBJ with the following settings.
11459.8 In reply to 11459.7
Imported into Blender 3.6.4 LTS
Next I selected the top ngon face and did an inset on it.
11459.9 In reply to 11459.8
After doing the inset, I deleted the now smaller ngon face.
11459.10 In reply to 11459.9
I then did a edge selection of the new hole.
Using Blender's gridFill I closed the hole with what looks to me, to be all quads.
11459.11 In reply to 11459.10
The final result in Blender. It took me a couple of minutes in vanilla Blender to do this.
Blender is a free and very handy app to learn and use.
I hope this achieves what you want.
Cheers from Nova Scotia.
EDITED: 12 Jul 2024 by KENMO
Size: 219.9 KB, Downloaded: 44 times, Dimensions: 2071x1329px
11459.12 In reply to 11459.11
Also in Blender I used the commercial plugin, Quad Remesher which is usually my goto app for retopo work but it failed on your model and was not able to produce any acceptable output.
Next I imported your model into 3D Coat 2024.24 and converted to an voxel object and using the auto retopo I was able to convert, but the mesh is too dense with a count of 7,000.
11459.13 In reply to 11459.12
Next I exported the object I retopp'd in 3DCoat into Blender and ran Quad Remesher of the 3DC object. I set the target for 500 quads and it gave me a remeshed object of 1200 quads.
It was must simpler and quicker to remodel the top in Blender.
Show messages: All  1  2-13
