Filetting Filigree
All  1-2  3-10
11458.3 In reply to 11458.2
Thank you Pilou, separating forms is no problem. The issue is I'd like to have the solid patterns rounded at the top and not just a small fillet along the edges.
Like this:
How would I go about doing that?
Many thanks,
Gunter
EDITED: 15 Jul 2024 by GUNTER511
11458.4 In reply to 11458.3
Hi Gunter,
Is this for 3D printing, for CNC milling, or for rendering?
- Peer
When you draw with less sharp angles you can increase the fillet!
Here 4 max 4 for example so x 10 from above
Don't seen your last example! :)
11458.6 In reply to 11458.4
Hi Peer,
It's for 3D resin printing.
Gunter
With your last example
I believe that you must make some lofts so some sections! ;)
Or some ideas by Barry H
http://moi3d.com/forum/index.php?webtag=MOI&msg=11206.1
EDITED: 3 Jul 2024 by PILOU
Or some subdivisions... ? :)
Look at this bible thread of subdivide in MOi! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
11458.9 In reply to 11458.6
Hi Gunter,
Since this is for 3D printing you are almost certainly better off using a different type of software like ZBrush. Here's a tutorial on filigree.
https://www.youtube.com/watch?v=n6TVd7vZSII
Making filigree in MoI, or any other NURBS CAD software, would be quite challenging and time consuming. The only reason I can imagine doing that would be if the part needed to be milled.
- Peer
11458.10 In reply to 11458.3
Hi Gunter, yes like Peer writes above it will be difficult to make an organic form like you want in a CAD program where the focus is more on mechanical parts.
You may want to check out 3D Coat in addition to ZBrush for making that type of model.
Show messages: All  1-2  3-10
