BoundingBox Info node
All  1  2-4
11457.2 In reply to 11457.1
Hi Barry, it's probably either a bug or possibly a malformed trim boundary where pieces of the larger underlying surface are incorrectly being targeted in the bounding box calculation.
You might try running ShrinkTrimmedSrf on it to see if that helps.
It's not likely to be from your script code.
If there are any geometric anomalies like self intersecting surfaces or trim boundaries those could be the cause as well.
> However Moi shows the correct sizes in the top right display.
The top right display uses a different method, it's based off of the display mesh so it can be quick.
11457.3 In reply to 11457.2
Thanks Michael,
had tried the shrink surface but no difference.
Barry
11457.4 In reply to 11457.3
Hi Barry, it's difficult to help with a geometry specific issue without being able to work with the geometry.
The object looks like it might be kind of lumpy and bumpy - is it possible that there are areas of self intersection in its surfaces or trim boundaries?
Show messages: All  1  2-4
