Doming object on surface
All  1-5  6-13
11449.6 In reply to 11449.4
Pilou, not sure I understand.. the flow is on the surface not the circle, right?
Gunter
11449.7 In reply to 11449.3
Hi Gunter, is this getting close to what you need? I trimmed out a portion of your top ring surface to use as the target for Flow, and added a base plane under the ellipse part.
11449.8 In reply to 11449.5
Hi Gunter,
> but I'm getting this stretched version..
There are 2 ways to limit it to the upper area - either extend the base plane so the base object will be located within a portion of the target surface, or use Edit > Trim to cut the target surface to a smaller area, I did the 2nd one above.
11449.9 In reply to 11449.7
Michael, thank you very much for your input, yes this is exactly what I was looking for!
For future reference, I'd like to understand the logic of first trimming the top surface of the ring please? Is it to just restrict the lattice from stretching?
Why is this not needed when you use curves as I did before?
Apologies for the questions but I need to wrap my head around the reasons so I know what to do in a similar situation down the line.
Many thanks indeed.
Gunter
11449.10 In reply to 11449.9
Hi Gunter,
Yes, because in surface-to-surface flow mode it will match the entire base surface to the entire target surface.
Curve-to-curve flow has a "stretch" option that you can turn on or off unlike surface-to-surface flow.
In curve-to-curve flow when "stretch" is off it will match distance traveled along the curves. But it's difficult to have that type of matching in surface-to-surface flow because there isn't just one direction anymore, a surface can easily stretch or compress to different widths at different spots along it.
11449.11 In reply to 11449.10
Hey Michael, Thank you for taking the time to explain this, I get it now.
Much appreciated
Your line is 20
If i take a part of circle of 20
Flow the part Line to Part of Circle will give the result wished! ;)
EDITED: 27 Jun 2024 by PILOU
In fact the Flow method can support some styles of results! :)
Depend of what result wanted with Line, Surface, Volume...
...and where are the different items
Line - Line : strict ... volume follows line
Line - Surface : can be degressive ... volume can enter inside the surface
Surface - Surface : Strict ...volume follows the surface
Show messages: All  1-5  6-13
