一个独立的视口截图工具取自M3DCH UI(An independent viewport screenshot tool taken from M3DCH UI)
All  1-2  3-5
11448.3 In reply to 11448.2
HI BurrMan
这太棒了,但我认为制作成可调用的js脚本而不是使用代码调用的意义:
(This is great, but I think the significance of making it a callable JavaScript script instead of using code calls is:)
就是人们不再需要记忆、理解长长的代码,而使用自身文字来定义快捷键,我想这对一些人会很重要(It means that people no longer need to remember and understand long codes, but use their own language to define shortcut keys, which I think will be important for some people)
11448.4 In reply to 11448.3
Hi Suiyan,
So you can do it either way
If you have “inline” code, you can just add it to a text file with a “.js” extension. Then the command is whatever you name it.
So from your screenshot, “alt-s” then for the command put the name of your new js file (that you added to the command or scripts folder in your install directory)
11448.5 In reply to 11448.4
Thanks BurrMan,我才想到这么做(Thanks BurrMan, I just thought of doing this)
Show messages: All  1-2  3-5
