Line thickness when exporting
All  1  2-3
11446.2 In reply to 11446.1
Hi Brianfox90,
I use the same workaround as you show: put a small surface object in the scene to get the options to appear, and then erase the edges of the surface from the exported PDF.
But, you made me think of another that avoids editing the PDF. Add the surface object to the scene and then hide its edges. This won't work if you are generating outlines / silhouette though.
- Peer
11446.3 In reply to 11446.1
> Is it possible to have the line adjustment option appear when exporting even if there are no surface objects?
Currently a wireframe export will only use a hard coded 1pt line weight but I have set up the "Line style options" for wireframe exporting for the next beta version.
Show messages: All  1  2-3
