Better way to surround objects with rectangle?
All  1-3  4-10
11440.4 In reply to 11440.3
What is "the Custom UI".
I was actually about to say I think MoI needs a menu with all the commands that are currently not discoverable via the UI.
11440.5 In reply to 11440.4
CustomUI is a UI mod that adds some buttons on the bottom toolbar, one of them is for a "Scripts" menu:
https://moi3d.com/wiki/MaxScriptArchive
Look for CustomUI.2.0.beta2.zip near the top
Or also here's one with just the menu:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10353.1
11440.6
Please remind me how to install this menu. I copied Extras.htm and Extras.js from the zip file to %AppData%\Moi\commands and restarted MoI but no button appears at the bottom.
11440.7 In reply to 11440.6
Hi Andre, this one needs to go into %AppData%\Moi\startup
Message 11440.8 deleted 21 Jun 2024 by SUIYAN
11440.9 In reply to 11440.6
Extras.htm and Extras.Should be placed inside C:\Users\Administrator(you user name)\AppData\Roaming\Moi\startup
如果需要定制你的脚本菜单,请参考http://moi3d.com/forum/messages.php?webtag=MOI&msg=10353.1 Larry、Michael、Pilou还有我的发言。
(If you need to customize your script menu, please refer to Larry, Michael, Pilou, and my comments)
11440.10 In reply to 11440.6
@ Andre
If you have a Windows OS ... the Moi StartUp Folder is here !
C:\Users\your user name\AppData\Roaming\Moi\startup
Maybe this AppData \ Roaming can be hidden !
so first enable Show Hidden Files
Windows is a mess!
Bon courage! :)
Show messages: All  1-3  4-10
